CCT Replacement (fix the engine rattle for good)
Old Feb 2, 2011 | 12:06 AM
  #81
FLspeedracer's Avatar
I dont think the coils are in the wrong position because i never touched them, but I guess its possible that maybe one coincidentally went bad while i was doing this. Worth the effort to check I suppose.
Old Feb 2, 2011 | 08:33 AM
  #82
Dissevered's Avatar
Explaining the way a car/bike sounds can be difficult and everyone gets different ideas of the "sound" through words used so maybe I am giving you the wrong advice based off of your harley sound explanation.
If you have a bad spark plug wire or coil, your bike will sound odd, almost deeper and throaty. This is easy to check though, just pull your plugs and test for spark visually.
If you have switched your wires around, or screwed up your timing, you will hear what I perceive to be the harley sound. You will hear something very similar to back firing because your bike is igniting the air/fuel charge with the valves open.
Old Feb 2, 2011 | 02:44 PM
  #83
Well pretty much what I mean by the Harley sound is that one of the cylinders doesn't have the right compression due to timing or what have you. I still havent had a chance to check the coils so ill update soon.
Old Jul 18, 2011 | 09:03 PM
  #84
young7.3's Avatar
Great write up. I just got a 94 cbr with this same problem and was about to make a thread about it. Thanks for saving me the time.
Old Nov 6, 2011 | 11:55 PM
  #85
Phantom F2's Avatar
My F2 was doing having this rattle all last season I was just about to tear the whole engine down and replace the valves but hopefully this will solve it. Thank you for the help.
Old Mar 23, 2012 | 06:15 PM
  #86
stealthnet2004's Avatar
Default noob question..
Noob question here, but referring to the guide a second, when you say start the engine and check for the rattle then adjust; if it has to be adjusted do you need to turn the engine off to perform this adjustment? or can you adjust the manual CCT with the engine running?.
I was meddling with the original OEM cct and when my engine is running, if you take off the top bolt, it looks like the screw inside is rotating, is it doing that because it is lose? or is this normal?
Old Mar 25, 2012 | 12:55 PM
  #87
Dissevered's Avatar
I am not sure about what screw you are talking about. I forget what the OEM tensioner looks like, but I would really refrain from running the engine while doing anything that might resemble loosning the tension, or allowing it to loosen on its own. The cam chain could jump teeth and ruin your engine.
Old Mar 25, 2012 | 06:08 PM
  #88
Craig84's Avatar
idk about the OEM one, but while doing the Manual CCT I started mine then loosened it till I heard the rattle. After I heard the rattle I screwed it in till it went away and then tightened it, did it like that 2 years ago and it's still running strong.
Old Mar 27, 2012 | 10:29 AM
  #89
Craig 84, when you say you loosend it until it rattled, was your engine running whilst you was doing this?
Old Mar 28, 2012 | 08:22 AM
  #90
Dissevered's Avatar
You can do that with the manual CCT. Just be careful and know what you are doing while tinkering with an OEM one. They are not build the same as the manual CCT.
