CCT Replacement (fix the engine rattle for good)
Old May 11, 2010 | 03:30 AM
  #61
cardshark99va's Avatar
does any one have a vid or audio clip of what exactly the rattle sounds like? and what do i need to do to get rid of the clutch noise it rattles kinda loud when at idle
Old May 11, 2010 | 04:18 AM
  #62
also which oil should i be running?
Old May 11, 2010 | 08:01 AM
  #63
Sand.Man's Avatar
I run Amsoil full synthetic 10w-40, make sure you get Motorcycle specific oil.
The CCT sounds like a tin can full of nails in a paint shaker, if you can imagine it.
Video clips are generally deceptive, sound quality is usually poor and there's no way to tell where the sound is coming from.
Chances are, if you have a loud rattle and are still using the OEM tensioner it's a good idea to replace it.
I have a brand new F2 APE tensioner that I don't need, I gave my used one to a friend on the terms that he replaces it, and forgot to get him to order an F3 tensioner because I swapped motors. So I now have the F2 tensioner that I do not need.
Old May 11, 2010 | 08:03 AM
  #64
Sand.Man's Avatar
Also, I don't think there's anything you can do about the clutch scuffle sound. I replaced my clutch pack and the sound is still there when in neutral with the clutch engaged.
Old May 12, 2010 | 02:04 PM
  #65
sand man u have a pm. check ur mssgs
Old May 16, 2010 | 06:59 AM
  #66
does anyone have a cct that they could help me out with on the cheap? i need one badly and cant afford one until july due to the fact that i have to graduate college and move in 5 weeks
Old May 25, 2010 | 06:05 PM
  #67
compster's Avatar
How can you clearly distinguish between this sound and a valve adjustment being required. I'm new to the CBR having just bought a 1991 CBRF2. I also have a VTX1300 and it is a very noisy engine, but I'm unsure what to expect from this engine.
It sounds great revving, but at idle there's definitely some rattling sounds going on.
Old May 26, 2010 | 11:00 AM
  #68
Gacho's Avatar
Heres the rattle: http://www.youtube.com/watch?v=QCsvS...ext=1&index=24
If it sounds like that, then get yourself a MCCT
Atfer I installed my "home made" version, evrithing is fine, and no more rattle
Old May 26, 2010 | 01:45 PM
  #69
ljung's Avatar
Got mine by the mail from US and A today so might shifting from original one to APE this weekend :-)
Attached Thumbnails CCT Replacement (fix the engine rattle for good)-ape_manual_cct.jpg
Old May 26, 2010 | 07:14 PM
  #70
jk72180's Avatar
holy **** poor motor
