Air Filter question
Old Mar 24, 2010 | 08:25 PM
jagdiver's Avatar
Default Air Filter question
So I want to preface this with the fact i feel really dumb asking this. But i recently downgraded from the K&N Filter to the stock honda paper filter. My question is that its not labeled which way is up. so which is up? lol my filter has a metal type grate on one side and not the other. Anyone have any idea which way its supposed to go??
Old Mar 24, 2010 | 09:01 PM
Sand.Man's Avatar
I do believe the metal grate is the top side.
Old Mar 24, 2010 | 09:44 PM
dustinjklee's Avatar
i thought it would only properly fit one way i am probably wrong though. but i could have swore it would only work on one side. but i would think that it would tell you whice way is up or down
Old Mar 24, 2010 | 10:29 PM
Sand.Man's Avatar
The metal screen is for keeping large debris out from between the fins of the paper element... It would be useless if the metal screen was on the bottom.
Old Mar 25, 2010 | 02:29 AM
jnicola's Avatar
Not true at all. It would keep carb gremlins from moving up and through the filter, into the airbox, where it could then eat it's way into the gas tank, causing an explosion.
The metal always goes DOWN!
Old Mar 25, 2010 | 10:23 PM
jagdiver's Avatar
It just seemed to fit better with metal side down... but it could just be my airbox ... thanks guys ...
Old Mar 25, 2010 | 10:29 PM
Sand.Man's Avatar
My mistake, I had a look at the filter on my bench and the screen is a flash screen... It keeps flames contained in the lower air box in case of a back-fire
Old Mar 26, 2010 | 01:30 AM
jnicola's Avatar
Wait hold on... so I was right... it keeps stuff from coming out the carbs, starting a fire, and potentially causing your gas tank to explode?
Damn I'm good!
Old Mar 26, 2010 | 08:10 AM
Sand.Man's Avatar
I think they are more concerned with the paper air filter element burning up, but it could potentially be a big fire if there's something seriously wrong with your bike (IE, timing is way out causing combustion on the intake stroke)
sho24vdohc
Jul 6, 2010 09:53 AM
Kraxor
Apr 8, 2010 06:59 PM
cbrHurricane
Jul 1, 2008 03:10 PM
jDeArMeAmNy4
Jun 3, 2008 10:52 AM
tomc1965
Aug 8, 2007 11:03 PM
