Changing Sprockets (links or rechts) ?
Old Mar 23, 2010 | 07:48 PM
Sixcell's Avatar
Default Changing Sprockets (links or rechts) ?
Hi im about to change sprockets on my 93' F2
Is the front sprocket Links or Rechts?
& any good tips how to get it of the easyest way?
Old Mar 23, 2010 | 09:26 PM
randyjoy's Avatar
Rechts.
I put the rear tire on the ground, pull the front brake to prevent movement, and use a big socket wrench with a breaker bar. It is usually torqued pretty high.
Old Mar 23, 2010 | 11:11 PM
Sixcell's Avatar
Originally Posted by randyjoy
Rechts.
Thank you, i was thinking of putting on the new chain. then holding down the rear brake... while cranking on it
Should do the trick now that i know which way it loosens
Old Mar 24, 2010 | 01:59 AM
jnicola's Avatar
You could always get an impact wrench and do it that way.
Old Mar 26, 2010 | 02:46 AM
Hoosier1104's Avatar
Put it on a rear stand, put it in gear and start removal process. I did mine that way with no issues.
Old Mar 26, 2010 | 09:45 AM
randyjoy's Avatar
I've seen them so tight that it actually turned the engine over with no weight on the rear (buddy bought a used 954 and the last guy had used red Loctite on the sprocket).
Old Mar 26, 2010 | 09:39 PM
Sixcell's Avatar
Yea. not the case here... but it was hard getting it of.
I would maybe consider loosening the front sprocket first, then kutting of chain & removing the rear sprocket.
I kut the old chain first then started on the front sprocket, which resulted in the need for putting on the new backsprocket & the new chain to get of the old front one
makes it easyer...
F4itanner
Mar 7, 2008 11:51 PM
Stockrocket
Feb 18, 2008 05:54 PM
milko
Oct 25, 2006 02:12 AM
mirks
Apr 13, 2006 08:14 PM
rrasco
Apr 8, 2006 02:02 PM
