CBR Coolant
Old Mar 26, 2010 | 03:02 PM
darwinh22's Avatar
Default CBR Coolant
I've had 2 f2's with the same problem. At first I thought it was just my first f2 but the second just did this yesterday as well. When the bike starts to overheat the coolant expands and bubbles/boils out the top of the canister all over the ground? Whats going on with this?
Old Mar 26, 2010 | 03:05 PM
berga's Avatar
Instead of bubbling over, the overflow coolant should be flowing via the black tube into the coolant reservoir. Double check that isn't clogged and coolant can flow properly. Otherwise I would suggest buying a new radiator cap, because yours isn't sealing?
Old Mar 26, 2010 | 04:16 PM
Bently600's Avatar
Or you just have way too much coolant in the system (or did before it all came out).
Old Mar 26, 2010 | 06:10 PM
Sand.Man's Avatar
Or you have the wrong ratio of coolant/water, causing your coolant to boil in the first place.
Old Mar 26, 2010 | 09:54 PM
SpeedPhreak's Avatar
Remember coolant ratio no matter where you are should always be 50/50 that is the best protection hands down besides a good gun :P
Live to ride and ride to live!
mcastro253
Jul 2, 2012 05:13 PM
CBRHindle
May 1, 2008 11:34 PM
02cbrf4i4u
Jul 4, 2007 09:15 AM
exopforce
Jun 11, 2007 11:33 PM
osin41
May 29, 2007 01:50 AM
