Changing Sprockets again...
Old Feb 18, 2008 | 03:29 PM
Stockrocket's Avatar
Default Changing Sprockets again...
Well its about time for me to get new sprockets again. I was told that -1 down in the front is the equivalant of going +3 in the back. I know the most common setup is -1 +2 but I have my sprocket repainted to the color scheme of the bike so was thinking of going with a larger rear sprocket and just returning to the normal 16t front. So if I just got a +5 rear sprocket would it be just about the same performance/gearing as -1 +2?
Old Feb 18, 2008 | 03:51 PM
Onarom's Avatar
Default RE: Changing Sprockets again...
I believe that is correct, but if you go +5, keep in mind that you might need to order a longer than normal chain. It would suck to find that out while you are in the middle of installing it.
Old Feb 18, 2008 | 05:33 PM
knightslugger's Avatar
-1/+2 is a ratio of 3:1
in order to keep that ratio and have a 16T front sprocket, you'd need a 48T Rear Sprocket.
so yes, a +5 rear would do you perfect. except you'd need a longer chain.
Old Feb 18, 2008 | 05:54 PM
bobjoezx's Avatar
save your money on chain unless you wantw to replace it which is a good idea.. but just buy some links
BRRandon
Jun 9, 2008 09:28 AM
F4itanner
Mar 7, 2008 11:51 PM
milko
Oct 25, 2006 02:12 AM
mirks
Apr 13, 2006 08:14 PM
rrasco
Apr 8, 2006 02:02 PM
