rattling/buzzing sound on my 954
Old Feb 26, 2007 | 11:36 AM
12 O Clock's Avatar
Default rattling/buzzing sound on my 954
I have a 2002 954 and at first this sound started and it was just everynow and then when I got to redline or higher RPMs and it was just a faint rattleing/buzzing sounds of what sounds like change in a cup holder of a car going down the road,...now it's almost constant thru our my riding except on decel and very low rang rpms (between 1 and 4) does any one have any clue? it sounds like its coming from the front of the bike but I'm tightened all my fairings and checked the headlights from what I could get 2 without pulling everything off. Has anyone else had this happen? PLEASE PM and let me know if you know what I'm talkin about.
Thanks, James[/align]
Old Feb 26, 2007 | 08:07 PM
silvr002001's Avatar
Default RE: rattling/buzzing sound on my 954
every bike I have ever had has had some sort of faint, brief buzz somewhere in the powerband on harder acceleration. I doubt that helps you any though
Old Feb 26, 2007 | 10:40 PM
regener8ed's Avatar
sounds like the ol' CCT...
Old Feb 27, 2007 | 01:03 AM
bobjoezx's Avatar
just the vibration.. right tone/frequancy.. these are high revin'g engines taht cause alot of vibration.. i would look over the bike and tighted everything .. everything seems good i woudlnt' worry about it to much unless it gets really loud or you notice something else
Old Feb 27, 2007 | 04:30 AM
crazystang26's Avatar
had a bike once had the same problem, it was the starter, it would only make the noise at a certain rpm, if it was me i would start there,bu thats just my past, its a thought 4 ya
Old Mar 1, 2007 | 12:24 AM
mark21901's Avatar
had the same problem after a complete rebuild upper fairing was rubbing either brake fluid resovoir or it the clips on the inner fairings were worn out.. its been so long i cant remember which but it was definently something rubbing into the upper fairing
Old Mar 1, 2007 | 12:26 AM
mark21901's Avatar
if you ride wheelies check the stabilizer pins on your headlight they tend to wear out..
Old Mar 2, 2007 | 11:33 AM
Finn's Avatar
I have this very same vibrationsound in my 2002; 954 Model. Last summer I tried to find out from where itmight come. Have anyone taken away the exup and fasten the airflap in the airbox? I can feel the vibrationsound on all gears from 2-5 between 5000 - 7000 rpm. When I put the 6th gear and keep going around 7000 rpm the vibration is away. I have a feeling it has to do with the constuction of the exup and airflap in the airbox.
Thanks for good ideas, Finn
Old Mar 2, 2007 | 11:59 AM
12 O Clock's Avatar
well how would I go about replacing or fixing the stabilizing pens? cuz I tend to do a few wheelies
Old Mar 2, 2007 | 08:47 PM
bobjoezx's Avatar
they are on the headlight.. would have to take headlight off to look at the pins and gommets
JJZF4i
Jan 12, 2011 04:02 PM
bmwguy
Jul 31, 2010 07:35 PM
90Hurricane
May 8, 2009 08:26 AM
Drekkyk
Jul 21, 2007 02:15 PM
My600RR
Jul 24, 2006 02:08 AM
