Engine temp goes up to 125!!
Old Jun 19, 2014 | 11:52 PM
Colombo's Avatar
Originally Posted by Conrice
No problem, bud. Is your sig pic taken by the planetarium by chance?
It sure was
Old Jun 23, 2014 | 03:06 PM
mutley's Avatar
Hi All,
Temp would be in C Celcuis 125
I have just found the problem, the water pump is leaking
Old Jun 23, 2014 | 03:29 PM
mutley's Avatar
Does any one know were to get a good deal on water pump in the UK?
Thanks all
Old Jun 23, 2014 | 08:15 PM
Conrice's Avatar
Thanks all
Ebay Ebay Ebay.
But where is it leaking? You may be able to fix it.
Old Jun 25, 2014 | 02:57 PM
mutley's Avatar
Hi
It's leaking from the hole built in to the body.
I believe its there to prevent oil / water mixing?
I hope this helps
Old Jun 25, 2014 | 08:02 PM
CorruptFile's Avatar
June 2013 ROTM
Weep hole. And if its leaking, it is likely a bad seal.
Old Jun 26, 2014 | 02:55 PM
mutley's Avatar
When last out on the bike, came round a left hand corner and back tyre slipped!!
3 corners later I was home, left hand side of rear tyre covered in Antifreeze/water
A with in a moment or two a 2/3 inch puddle of coolant on the floor
Old Jun 26, 2014 | 03:23 PM
Conrice's Avatar
Well, I wouldn't wait to fix it. Drain you coolant, pull off your water pump, pull it apart, and replace that seal and o-ring (while you're at it). #5 and #10.
WATER PUMP
Take pictures, and put up a thread in the "How-to" section once you have it fixed. It'll help a lot of fellow riders.
Old Jun 26, 2014 | 05:47 PM
mutley's Avatar
Hi Conrice,
I will be ordering a pump this weekend from EBAY
I wish I didn't live in RIP OFF UK brand new over here the water pump (Same part number)
In the UK I have been quoted £195 = $331 !!!
In the good old USA $137 = £81 What a difference !!!
Honda should put a stop to this !!!
Yes I will do a write / with photos
Eliteedge0788
Feb 28, 2010 12:13 PM
inkrypt
Dec 15, 2009 09:37 AM
BluByU
May 14, 2009 10:16 PM
jimmyson
Mar 9, 2008 10:30 AM
NextYearCubFan
Aug 31, 2007 03:20 AM
