02 900/954 crank no start issues
Old Jun 13, 2018 | 01:37 PM
Thisguy's Avatar
Default 02 900/954 crank no start issues
I got a 02 900/954 and I cant get it to start. Issue is i turn key on fuel pump primes up fi light goes out and red light on dash comes on solid doesn't blink, I tried short the self check connector and cant get the light off and cant get the bike to run or even hit a lick. Please help thanks
Old Jun 13, 2018 | 01:48 PM
74demon's Avatar
Did the bike not start all of a sudden, or after work was done?
Is there gas in it?
Crank and cam sensors plugged in?
Is this a HISS system?
Old Jun 13, 2018 | 02:32 PM
Thisguy's Avatar
Is there gas in it?
all of a sudden, yes has a half tank, everything is plugged it as far as I know I haven't unplugged anything, I honestly do know what his is
Old Jun 13, 2018 | 02:59 PM
CaBaRet's Avatar
Have you tested start/stop switches, 10 amp starter/ignition fuse?
Old Jun 13, 2018 | 03:07 PM
Thisguy's Avatar
it turns over good found no issues with any of the fuses
Old Jun 13, 2018 | 03:50 PM
74demon's Avatar
The fact that it's cranking rules out a lot of things.
You have fuel pump, so you gotta check for pressure, spark, and injector pulse.
This happened to me once. It turned out that the rubber hose that connects the pump to the filter in the tank blew. I had a running pump, but no pressure. Just putting it out there...
Old Jun 13, 2018 | 07:36 PM
Thisguy's Avatar
yeah im going to check fuel pressure and do a compression check tomorrow, Im getting spark currently just seeing if anyone had a normal problem list to check.
Old Jun 13, 2018 | 10:43 PM
Thisguy's Avatar
Can anyone tell me the correct noid size I need, and fuel pressure specs
Old Jun 14, 2018 | 01:09 AM
CaBaRet's Avatar
Delivers 50psi at the injectors, also these 194 bulbs will do just fold down the wires
https://www.ebay.co.uk/itm/10X-T10-W...Tm_GWVfLIzegNg
Old Jun 14, 2018 | 01:57 AM
Thisguy's Avatar
Ok guys I am getting 50 to 55psi of fuel pressure to the rail. Spark on all 4 plugs. And all injectors passed the noid light. I'm going to do a compression test tomorrow night but any other ideas would be awesome and greatly appreciated I just wanna go ride lol
