Swapping Fuel Tanks
Old Nov 18, 2012 | 05:46 PM
YZBoy99's Avatar
Default Swapping Fuel Tanks
Hey guys, I was attempting to put a new (to me) fuel tank on my 929 and when I unbolted the fuel pump from the bottom of the tank, I noticed a pile of metal coils stuffed into the bottom of the pump, almost like drill bit cuttings...
Is this normal?
Also, when I swap over the pump to the new tank and go to fire it up, is there anything special that needs to be done other than cycle the fuel pump a few times with the key? Is there any special bleeding procedure?
As always, thanks again for all the great info on this site!!
Old Nov 19, 2012 | 10:11 AM
CorruptFile's Avatar
June 2013 ROTM
I'd say those metal shavings aren't normal! Is there an aftermarket fuel cap on the tank? PO probably didn't think about the metal falling into the tank. I'd make sure its all out before you put it all back together. A few good shaking rinses with a bit of fuel should do it.
Electric fuel pumps are self priming. You may want to cycle the key a few times.
Old Nov 19, 2012 | 05:56 PM
YZBoy99's Avatar
Yes, the PO that had it before me bashed in the top of the tank to make it into a stunt bike (by the looks of the side guard bars he was too chicken to try anything!!) and installed an aftermarket cap......geeez.
It's all making sense now....
Thanks...
Old Nov 19, 2012 | 10:34 PM
YZBoy99's Avatar
Well, after careful extraction, it turns out that someone dropped a steel scrubber pad into the tank and it somehow wrapped itself around the base of the pump. Almost like a wad of steel wool, and had to disassemble the pump mount to get it out.
....weird...
Old Nov 19, 2012 | 10:58 PM
June 2013 ROTM
Oh gawd...
What else could be wrong with that bike...
Old Nov 21, 2012 | 06:25 PM
bucklti's Avatar
Registered Users
Make sure to buy new crush washers for the banjo fitting. I tried to reuse mine but was unsuccessful.
Old Nov 22, 2012 | 07:09 PM
YZBoy99's Avatar
Boys, you can't imagine what I have all found with this thing!! Lol...been a make-work project for a couple months now.
Good thing it came pretty cheap.
Good thinking on the aluminum washers...to be honest I have had the tank off and on a couple times now with no leaks, but I'm sure I'm pushing my luck! Thanks!
jayalter
Apr 8, 2014 07:48 AM
FOGeologist
Jan 6, 2014 09:23 AM
fatluke_nofx
Nov 28, 2011 08:07 PM
VALKYIE
Mar 2, 2009 09:59 PM
CajunMike
Dec 21, 2007 07:15 PM
