Slipping Clutch?
Old May 2, 2009 | 02:26 PM
shopkins's Avatar
Default Slipping Clutch?
Rode my 01 929 yesterday and noticed it felt like the clutch was slipping when starting from a stand still. Once I am rolling it runs fine and still has all the power. Any sugestions? Also, has anyone replaced a clutch and where did you buy it from? Thanks...
Sean
Old May 2, 2009 | 11:06 PM
abs929cbrrr's Avatar
have you adjusted you clutch at all 1st? how many miles also?
Old May 4, 2009 | 07:52 AM
packdog's Avatar
as was said, check you're adjustments. if they're ok, pull the clutch cover, remove the plates and measure with a caliper. if you need specs i can find them, or you can download the manual (see link below). If you have to order a new clutch, I would go OEM. Don't forget: the clutch on this bike has 7 "common" fiber plates and 2 "unique" fiber plates. of the 2 uniques, one has a large inner diameter to fit around the judder spring, and the other unique has a different composition (i think) so it doesn't score the aluminum pressure plate. when doing the clutch job, hit the metal plates with 400grit sand paper to removing the glassing.
yz125
Dec 14, 2011 09:13 PM
Who Dat Popcorn
Oct 2, 2011 07:00 AM
adams_CBR600f2
Jun 25, 2009 02:46 PM
scantron
Feb 7, 2009 01:48 AM
HighRevver
May 30, 2006 06:36 AM
