Ignition problem
Old Jun 27, 2017 | 02:58 PM
Mitchell Pereira's Avatar
Default Ignition problem
I recently swapped the ignition because i broke my key. I bought a used OEM replacement. I plugged it in and nothing. No power whatsoever. Do i have to reset the ecu in order for it to work? Or did i get beat on a faulty igniti okkn switch?
Old Jun 27, 2017 | 05:43 PM
74demon's Avatar
Are you in the USA? Bikes from other countries have HISS.
There is a resistor in the switch that steps down voltage to 9V on the pink wire as a security measure. Make sure that's good.
You shouldn't need to reset anything.
Old Jun 27, 2017 | 08:42 PM
Yes im in tge US. It does have HISS. Both ignitions have identical wires
Old Jun 27, 2017 | 10:49 PM
74demon's Avatar
Since it has the HISS system, the ECM needs to match the key and ignition.
All the matching parts will cost more than the bike.... Any way to salvage your original ignition?
Old Jul 2, 2017 | 05:19 PM
i still have the original ignition. The wires have been cut. Im pretty sure it has HISS, BUT, the key it came with is just a cut key from a locksmith. There is no chip in it. Maybe it doesnt have HISS? I looked up the VIN and its a Japanese bike if that means anything. Why no power? Shouldnt it at least power up and prevent the pump from priming?
Old Jul 5, 2017 | 03:07 AM
CaBaRet's Avatar
Hi does your ignition look like this, (as regards the wiring) or does it have 3 wires (Hiss) with immobiliser
Old Jul 5, 2017 | 05:55 PM
it has 4 wires. I actually figured it out. Finally got it started but it has more issues now. One thing after another...
Old Jul 5, 2017 | 06:23 PM
74demon's Avatar
What was the solution?
Old Jul 5, 2017 | 06:44 PM
the most obvious reason. The main fuse was blown after i put the ignition in. Didnt think to check it. I guess it doesnt have hiss. Whoooops 🤗
nthauscbr
Apr 1, 2008 06:38 AM
GuywithF4i
Jul 8, 2007 08:16 PM
fireman2670
Jun 2, 2007 07:11 PM
tank_900rr
Jun 1, 2007 07:46 PM
CBRChink
Dec 13, 2006 02:05 PM
