F4i ignition problem, maybe?
Old Jul 8, 2007 | 04:05 PM
GuywithF4i's Avatar
Default F4i ignition problem, maybe?
Bike is an 03 F4i w/ about 5K on it. It just started giving me a low rpm stutter below 3K which was really bad and seamed to progressively get worse the more I rode. Also had sporadic moments while cruising where it sounds like I am dropping a cylinder and then it comes back again. Never had this issue before and seeing if anyone had any other suggestions before I started w/ the usual, which would be new plugs and going from there. Also idling a little low and started to stall at a stop, but bumped the rpm's up and that helped with that issue but did not completely resolve it. Idears?
Old Jul 8, 2007 | 08:16 PM
GuywithF4i's Avatar
Default RE: F4i ignition problem, maybe?
n/m, nut fell off the back of the neg terminal on the batt and causing grounding issuse, yeah for .25cent fix!
Sabotage
Oct 21, 2014 01:02 PM
Ussrdolphin
Oct 19, 2014 02:06 PM
akareem27
Jul 31, 2010 11:21 AM
tank_900rr
Jun 1, 2007 07:46 PM
CBRChink
Dec 13, 2006 02:05 PM
