ignition problem need help please
Old Jul 30, 2010 | 05:38 PM
akareem27's Avatar
Default ignition problem need help please
I took a ride today and everything was fine till i came to a stop at the destination.When i turned the wheel to the left the bike would lose all power!
So i found the wires that was causing the problem. I was playing with the wires and then i accidentally pulled them all out!!! so i was touching the two wire so see which one would get the spark to start the bike.found it (smile in the inside)
went to go strip the insulation to tie it together to get the bike home and the wire sparked touching the metal wire cutter. so no power,wire touching doesnt do anything and the fuses arent blown,i just checked. help im stuck out here for right now
Old Jul 30, 2010 | 07:41 PM
Probably poped the main 30a fuse by the battery. Nothing works if that fuse is blown.
Old Jul 30, 2010 | 08:27 PM
akareem27's Avatar
I switched that fuse with a new one just in case,no luck --after reading a lil bit more i think i need a new ignition
Old Jul 31, 2010 | 11:21 AM
Killa96CBR600's Avatar
man i hate to hear that buddy I dont think you need a new ignition though idk could be but anything to do with the ignition could be fixed and the hot wire should still be hot check to see if there are any hot wires on the bike from the ignition if not track back fom the ignition and see where the hot wire wen't your problem may lie there
Sabotage
Oct 21, 2014 01:02 PM
Ussrdolphin
Oct 19, 2014 02:06 PM
GuywithF4i
Jul 8, 2007 08:16 PM
tank_900rr
Jun 1, 2007 07:46 PM
CBRChink
Dec 13, 2006 02:05 PM
