issue with Neutral light......
Old Aug 11, 2011 | 06:52 PM
Cognac's Avatar
I'll give better detail.....sensor switch is spring loaded, in my case over time the contact point driven by the spring was worn down to the nub thus losing contact when getting hot.
sensor switch is located above the gear shifter, unplug the wire to the switch and screw it out using socket wrench (forgot size), but install new switch and plug wire back on and good to go..... 2 minutes
Old Apr 20, 2012 | 04:19 PM
Joey B's Avatar
I have a 99 that had that problem. all I had to do is take the sensor out and clean the connection. then I crimped down on the connector itself a little. mine was just wiggling itself loose
deadboy519
Jun 24, 2019 12:36 AM
pistolpete417
Apr 19, 2013 03:44 PM
beansrmajikle
Oct 31, 2011 12:07 AM
Sinatra
Jun 10, 2010 01:19 PM
mpgscott
Apr 3, 2009 02:18 AM
