issue with Neutral light......
Old May 6, 2011 | 10:57 AM
Cognac's Avatar
Default issue with Neutral light......
ok....I have a 94 900rr, lately Ive been noticing while driving for a little while (especially now that its hotter weather) that while riding and putting bike in neutral the light starts to flicker then sometimes goes all the way off . then when Im ready to park I have it in neutral with engine still running and when I lower kick stand the bike shuts off as if the bike is thinking its in gear still.
has anyone had this problem?
I dont have this issue when bike is cold or cool weather
Old Jul 1, 2011 | 02:00 AM
hitman510's Avatar
I'm having the same problem with my 9rr now... WTF right... then i got to wait for the bike to cool in order for it to start working again... fml
Old Jul 1, 2011 | 08:34 AM
Cognac's Avatar
exactly....I also noticed that when warm and light flickers off, when I tilt bike to the left light starts to come on again....but hotter it gets the more I have to tilt it
Old Jul 1, 2011 | 12:33 PM
estate4life's Avatar
February 2012 ROTM
Default Switch??
If light flickers, sounds like an electrical switch? Sticky switch. Neutral switch? When in neutral or in gear, there must be a switch relay signal to neutral light. When kickstand is down, there is a kick stand switch shutting down motor if in gear. I never experience anything alike what you state, but hearing the problem, I would look in this direction? Good luck and keep us
Old Jul 11, 2011 | 10:45 AM
Cognac's Avatar
did some more research and everything points to the "Neutral sensor switch".....part is about $25, ordered it...so will post again and let you guys know if it fixed the problem
Old Jul 11, 2011 | 03:05 PM
February 2012 ROTM
Great! Hope you fix problem prompt. Let us know status...
Old Aug 9, 2011 | 01:19 PM
Cognac's Avatar
wow...forgot about this thread, yes my neutral switch went bad, replaced and is all good
Old Aug 9, 2011 | 06:07 PM
February 2012 ROTM
Nice....was it hard to do....1 to 10?
Old Aug 10, 2011 | 12:55 PM
Cognac's Avatar
not hard at all, sensor is located above the gear shifter with wire that leads to the starter....
Old Aug 10, 2011 | 02:00 PM
February 2012 ROTM
Tks...i have a 94....Good info to have just in case i run into same problem.
