chain
Old Aug 30, 2006 | 03:54 AM
Slow900RR's Avatar
Default chain
ok guys tonight i was flying down the express way at like 170 and i herd a pop and i thought i blew the trans. turns out the the ****ing chain snaped. wtf it was late i sat on the side of the express way for 2 hours . going to buy a new one 2marrow gota ny suggestion on witch one to buy . thanks guys
Old Aug 30, 2006 | 05:01 AM
rippn's Avatar
Default RE: chain
I Like DID's... Look at the tensile strentgh rating, for any you consider. My buds at "1888fastlap" have 10500lb chain, for 139$, on special. tell'm Ripp'n sent ya!!!!! Regester online, and ask for a "deep discount" Give'm a call... 1-888- fastlap( e.st) Hey, I think they have spockets on special too !!!!!! Clean and free, Ripp'n
Old Aug 30, 2006 | 11:14 AM
Err's Avatar
Err
Default RE: chain
if you want to stunt make sure its a 525.
Old Aug 30, 2006 | 04:49 PM
gixxereater's Avatar
Default RE: chain
Uh? Im at a loss. Good luck.
Old Sep 27, 2006 | 10:55 AM
JAYS900RR's Avatar
Default RE: chain
WHY WOULD A 525 CHAIN BE GOOD FOR STUNTIN?.. IS THE 530 CHAIN GOOD?. I'M ASKING BECAUSE I BROKE 2 530 CHAINS IN A MONTH.. IS THE BUSA CHAIN A STRONGER CHAIN?..
Old Sep 27, 2006 | 01:03 PM
Err's Avatar
Err
Default RE: chain
how the **** do you break 2 chains in a month? are you putting them on correctly?
Old Sep 27, 2006 | 01:22 PM
IronFox's Avatar
Default RE: chain
525 is the stock chain size. If you go lower to say a 520, you`ll get a little more in the low end and diffrent sprockets are needed.
Old Sep 27, 2006 | 03:27 PM
Tahoe SC's Avatar
Default RE: chain
you won't notice much between 525 and 520!?!?!!?!
yea no matter how hard you beat on them...they shouldn't snap unless you buy crap chain or install improperly...
i'd bust a DID 525 or 530, if you're worrieda obut breaking them...as far as busa chain...there's not such thing...you put whatever you want on that thing...it's still a 530 chain...
Old Sep 27, 2006 | 06:59 PM
DMACK's Avatar
Default RE: chain
I am ready for a new chain as well. I have about 12,000 miles on the current one, and it's getting close to the new chain mark on the adjustment blocks. My question is 525s are stock, who make the strongest chains in the stock configuration? Is there a stronger set up I should consider as I am going to change sprockets as well (520-530)? And who makes the gold chains, I like the look of those? Vortex sprockets would seem the likely choice. Stick with the steel or go with aluminum? I commute on my bike every day to work, but also go on twisty canyon trips at least once a month.
Old Sep 27, 2006 | 08:35 PM
Tahoe SC's Avatar
Default RE: chain
chain color...many companies make them...almost all actually.
chain brand...DID x-ring!!!
stick with 525 chain and 525 sprockets. 520 will wear out a bit faster and you reall won't feel much of a difference from 525.
as far as sprockets...go with steel...aluminum is ok but if you're commuting and riding hard, will wear out too quickly.
brandwise, most are pretty good...just don't go with the el cheapo deal of the week ones.
davedude44
Jun 28, 2012 12:22 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
crookedeyemotocross
May 4, 2006 10:14 AM
