cbr900 fireblade not cold starting
Old May 21, 2018 | 04:45 PM
efjay's Avatar
Angry cbr900 fireblade not cold starting
hi all ive got an HONDA CBR900RR 1995/1996 model .
first a bit off history on the bike.
the bike was rebuild completely from 2 bikes as it was in a major accident about 3 years back
engine was repacked with new bearing and oil rings(no valve stem seals tough)
rebuild took about 3 months got it up and runing but ran in to some problems since so took it to a bike dealer to sort it out on the dyno ,
he then replaced the following spark plugs,pickup,carbs,module inside the rpm counter after a bit of tuning the bike ran great for about 2 weeks
then suddenly i picked up an issue with starting if the bike was standing for about 2-3 hours i have to bump start it and it takes a while trying to get it started
i have tried jump starting on a proper booster starter swings over but does not start at all
i have since changed spark plugs cleaned out the carbs again but still no improvement
any idea on what can cause this your advise will be appreciated thank you in advance
Old May 22, 2018 | 04:24 AM
CaBaRet's Avatar
Have you checked the rubber Insulators from the carbs to the engine make sure their screwed down tight as they could be destroying the vacuum, I see you've had the carbs off a couple of times, also check the vacuum pipes are clear at the tank
Old May 23, 2018 | 01:27 AM
efjay's Avatar
does anybody maybe know the correct air/fuel mixture screw setting for the bladefound that they were not set equal on any of them
Old May 23, 2018 | 01:56 AM
CaBaRet's Avatar
Should be 2 to 2 1/2 turns out
pocfoo
Jan 26, 2011 10:35 PM
chetman7
Oct 21, 2009 10:52 AM
kilgoretrout
The Hurricane Saloon
22
Apr 27, 2009 09:02 AM
transambird_2000
Nov 24, 2008 08:53 AM
DukeCBR
Mar 17, 2008 02:22 AM
