buzzy tank
Old Mar 20, 2007 | 01:53 AM
bosshaus1's Avatar
Default buzzy tank
anyone know a good solution to a buzzing tank...it's not all that bad but just enough to bug me...the only thing wrong with my ride
Old Mar 20, 2007 | 02:39 AM
morehpforme's Avatar
Default RE: buzzy tank
Do you have all the OEM rubber pads installed??
There should be a rubber pad for each mounting bolt and two others on the sides of the tank, between the tank and the frame rails. See the diagram below. #7, 10 and 14 are the rubber pieces.
Old Mar 20, 2007 | 11:15 PM
bosshaus1's Avatar
i am minus the two rubber pads, thanks man
Old Mar 21, 2007 | 09:25 PM
DevenJames2005's Avatar
If you cant get the rubber anywhere, you can use any piece of rubber or just cut and old heater hose and wrap it around the grooves on the outside of the tank
Old Mar 21, 2007 | 09:31 PM
bosshaus1's Avatar
already cheated...the dealer wanted $8 a piece for them. so i made my own. worked like a charm. thanks guys
Old Mar 23, 2007 | 05:49 PM
900RR Puzzle's Avatar
ORIGINAL: DevenJames2005
I saw somewhere that someone had also used those self-adhesive black rubberblocks that Walmart, Home Depot, etc. sell for furniture. They are dirt cheap.
Old Mar 24, 2007 | 06:08 PM
cloudbreakmd's Avatar
I actually just used some thick double sided tape on my F2 when I found the pads missing.
dsenk48
How-To: Mechanical
Sep 22, 2013 08:09 AM
SACBR
Jun 19, 2011 11:09 PM
jveach
Jun 12, 2011 12:45 PM
sawnee
Sep 22, 2008 10:40 AM
