1996 CBR900rr shift shaft removal???
Old May 5, 2010 | 09:17 AM
SEEYA7's Avatar
Default 1996 CBR900rr shift shaft removal???
How do I remove the shift shaft (shift rod)??? Do I need to remove the entire clutch??? Seal is Leaking. I can actually see the seal and where it Leaks from.
Old May 5, 2010 | 04:24 PM
cbr900racer77's Avatar
Yup, clutch basket has to come out. Easy job. Then after removing shift lever, it just pulls out from the clutch side. It's attached by a spring on the shaft, just give it a good tug and it'll come right off. There's a small black washer on the shaft, make sure you keep up with it, it's easy to lose.
Old Nov 26, 2010 | 08:25 PM
breethwithme's Avatar
mine was leaking on my 99 and i just used the smallest allen wrench i had and slid it behind the seal and pulled it out came out pretty easy just be carefull not to hit the shift shaft to hard. i heard you had to go threw all that so i tried it a differant way and walla. still dosnt leak after 10,000 miles. sure wish i would have seen this thread earlier i could have saved you alot of time.
j4eric
Jan 22, 2013 04:46 PM
wmk1975
Sep 11, 2012 06:49 PM
tomttt
Aug 18, 2012 05:57 AM
RyanEricW
Jul 19, 2010 10:19 PM
