Rear brake issues: Need advice
Old Jul 28, 2008 | 10:31 AM
Kleetz's Avatar
Default Rear brake issues: Need advice
Hey guys, I have an 03 600 RR. My buddy and I were riding around and he pulled me over to tell me that my rear brake is constantly on. Turns out that the rear brake lever kinda gets stuck in the down position and wont pop up enough to turn the brake light off after using it. (if that makes sense)
Is something not lubed enough? something too tight? what would be causing this??
Thanks!
Old Jul 28, 2008 | 11:23 AM
WhiteDealershipRice's Avatar
Default RE: Rear brake issues: Need advice
(easy fix)
Check the adjustment for the rear brake's light sensor.
or you can check the return spring for the pedal
as long as the sensor is not bad, it should be basic maintenance
Old Jul 28, 2008 | 12:02 PM
Slyncka's Avatar
Yeah I know that mine has a spring there that seems to help it come back to its normal position, check for that. Im not sure about the 03 but thats how mine is.
Old Jul 28, 2008 | 12:07 PM
Kleetz's Avatar
sweet sounds good. I love easy fixes!!! I'll take a look at it next time I'm around it (since the bike is at my buddies house).
Anyone know if the 03's have the spring that Slyncka is talking about??
Thanks guys!
Old Jul 28, 2008 | 10:50 PM
TK954RR's Avatar
Jan 2009 ROTM
Or you can do what i did, remove it, and ziptie it up above the trans somewhere outa sight
Old Jul 29, 2008 | 04:26 AM
skitzofrenzy's Avatar
tk haha for the avatar.
your brake light sensor is just sticky find it and punch it or something to make it work again.'
cwkhorne
Mar 11, 2013 10:09 PM
CatDaddy512
May 14, 2010 06:51 PM
Black Rider
Nov 1, 2009 06:09 PM
txsmainevent
Aug 9, 2007 04:30 PM
