Help with hids!! i think i burned my wiring!!
Old Jun 11, 2009 | 08:21 PM
bran89's Avatar
Angry Help with hids!! i think i burned my wiring!!
So i got a set of ddm tuning hids 55w 4300k. Freaking bright as hell.
Had them installed for like 3 days or so and they functioned perfect.
I noticed that my high beam indicator light wasn't on and both my lights
were out. Checked the fuses all good. No power at the sockets where i
plugged in the - and + for the ballasts. I'm afraid that my wires are all burned
up. I bought the relay harness online just a few hours ago, but i cant hook it
up until i have power at the stock harness. Please help!!
Old Jun 12, 2009 | 07:21 AM
tenjio's Avatar
Have you checked the fuses yet?
Old Jun 12, 2009 | 08:49 AM
bran89's Avatar
yea i checked all the fuses in the small box under the left fairing and it never blew any of those fuses
Old Jun 12, 2009 | 09:06 AM
tenjio's Avatar
Sorry... I meant to say have you checked the fuses under the driver seat?
Old Jun 12, 2009 | 09:16 AM
bran89's Avatar
the 20amp was fine (i think its the FI or something) and the big 30 amp green one is fine. Is there anymore?
Old Jun 12, 2009 | 09:41 AM
tenjio's Avatar
I think this diagram is for a 2005-06...
http://www.motoinfo.yoyo.pl/Honda/Honda%20CBR600RR.jpg
If you think your wires are burnt up unhook the battery, then check the resistance between two points on the wire you think is burnt up, it should be 0 if it's good. I would doubt you burnt up your wires and I would consider swapping out the headlight fuses under the fairing even if they appear to be good.
Oh... and also check the headlight relay.
Old Jun 12, 2009 | 05:16 PM
bran89's Avatar
yea my wires don't look like they are fried. Is the headlight relay also under the left fairing? I see three in a row. Sorry i'm new to all of this. I'll get a multimeter later tonite and test it out
Old Jun 12, 2009 | 05:50 PM
sUshI's Avatar
yea, best thing is to test all your wiring, starting from the power out, then for the ballast, ( if you have separate ignitors). then before ignitors. Plug in HIDs and turn bike on..meh, its always somthing simple. Burning out wires is very unlikely, fuse would go long before that. Thats the point of fuses, to protect devices and wires enroute..
Old Jun 12, 2009 | 05:52 PM
sUshI's Avatar
If there is an open circuit, you will have infinite ohms..you'r meter should read 'OL'. If the wires are ok, you should have like 0.8 ohms or something, any more than 10 ohms resistance, redo your connections..
Old Jun 12, 2009 | 10:53 PM
bran89's Avatar
thanks for the help i'll let you know if i find something tomorrow night
jacobray69
Jul 11, 2020 03:08 PM
jfre9193
Oct 13, 2013 10:34 AM
halffast1g
F2 Tech
May 27, 2010 08:17 PM
ugly
Aug 11, 2009 11:11 PM
TBFGhost
Feb 24, 2009 06:22 PM
