Wiring GPS (12 v socket), already have HIDs
Old 10-11-2013, 12:25 AM
jfre9193's Avatar
Default Wiring GPS (12 v socket), already have HIDs
Hello, just wondering if I'll go over my voltage if I install a 12v socket on the same circuit/fuse as my headlights. I currently have 8k HIDs.
Thanks!
-Josh
Old 10-11-2013, 06:47 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
You won't go over your VOLTAGE, it's the amps that count. 12V is still 12V. Figure up how many amps the HIDs use, see what the GPS current rating is and add them all up.
watts / volts = amps
Old 10-11-2013, 10:09 AM
jfre9193's Avatar
It's a used bike, I have no idea what amperage it uses, the gps is a tomtom one 125.
Old 10-11-2013, 10:31 AM
jfre9193's Avatar
it's 1.0 amp for the charger.
Old 10-11-2013, 12:30 PM
74demon's Avatar
Why do you want to connect it to your headlight circuit? The HIDs are a strain on the system as it is. There are other, and better, 12v sources to tap into.
Old 10-11-2013, 05:13 PM
RoadiJeff's Avatar
What wattage are the HID bulbs and ballasts - 35, 55 or what? You can calculate the current draw (amps) once you know the wattage using the formula I posted previously. The GPS should say how many amps it uses somewhere on it.
Old 10-11-2013, 10:07 PM
jfre9193's Avatar
1.0a for the gps, no idea about the HIDs, is there a way to tell from just the set itself, I bought the bikee off craigslist
Old 10-11-2013, 10:40 PM
RoadiJeff's Avatar
It should say somewhere on the ballasts if you can see them.
Old 10-12-2013, 10:54 AM
jfre9193's Avatar
There's the only thing I could find, not sure if that's it.
Thanks again, all.
Old 10-12-2013, 06:36 PM
RoadiJeff's Avatar
The HIDs are 35W.
35W / 12V ≈ 3A (each ballast)
Quick Reply: Wiring GPS (12 v socket), already have HIDs
