Brake Noise
Old 07-17-2006, 12:56 AM
D2VW14_20's Avatar
Default Brake Noise
My bike is literally brand new. It has 32 miles it. I was wondering if it was normal for it to make a smooth grinding noise. Its a higher pitched kinda like a metal on metalsound. I didnt know if it was just how the brake sounded or it it was just being broken or worn in. Let me know if this is wrong, beause if so, there is a bunch of s*** wrong with m bike! Thanks Guys/Ladies
Old 07-17-2006, 01:01 AM
Default RE: Brake Noise
it's normal. I'll bet it goes away the moment you touch the brake...
Old 07-17-2006, 02:25 AM
mine did that for the first couple weeks... it goes away
Old 07-17-2006, 02:31 AM
D2VW14_20's Avatar
It makes that noise when i apply the brake and goes away when i let go
Old 07-17-2006, 02:40 AM
Go brake hard several times in the street,(where it's safe) just go and progressivly brake harder each time. Make sure you can keep control but do this several times and see if it helps.(and use both brakes!)
Old 07-17-2006, 02:55 AM
D2VW14_20's Avatar
What will this do? Break um in and rub them down? Just curious.
Old 07-17-2006, 12:56 PM
what it does is bed the pads into the rotor.
Old 07-17-2006, 01:15 PM
ORIGINAL: knightslugger
With the miles he has on the bike, they should already be bedded in...and with the stock pads from the factory that shouldn't be an issue...they're always in contact with the rotors and they make a rubbing noise which is completely normal. My bike is almost 4 years old and still makes that rubbing noise!
Old 07-17-2006, 01:40 PM
D2VW14_20's Avatar
Alright. Good. So my bike isnt broke!! Haha!! Thanks for all your help guys
hondachris1994
03-06-2009 12:21 AM
Wildcard
06-08-2008 09:37 PM
Mikes03954RR
09-14-2007 03:18 PM
JC1000RR
03-21-2006 06:24 PM
JC1000RR
02-13-2006 08:25 PM
Quick Reply: Brake Noise
