Brake Noise
Old Sep 12, 2007 | 12:15 PM
Mikes03954RR's Avatar
Default Brake Noise
So I have had this squealing noise all summer with my front breaks. I took some break cleaner and cleaned off the rotors and it went away for a while. Now it is doing it again. The breaks are fine. They are not worn down to the wear plate. Does anyone else have this problem? If I change my pads will this go away. What kind of pads should I get? Any suggestions?
Old Sep 12, 2007 | 07:06 PM
bobjoezx's Avatar
Default RE: Brake Noise
get some of that anti squeal stuff you can find at any parts store .. take your pads off and spray/lube the BACK of the pad really well and reinstall them.. it's vibration in the braking that u are actually hearing, same thing with cars, but if you need new pads do it at the same time
Old Sep 12, 2007 | 07:34 PM
TCIRACING's Avatar
EBC MAKES PRETTY GOOD PADS, I HAVE THEM ON MY BIKE RIGHT NOW, NO COMPLAINS.
http://cgi.ebay.com/ebaymotors/EBC-H...spagenameZWD1V
Old Sep 12, 2007 | 08:23 PM
bobjoezx's Avatar
i agree EBC is good
Old Sep 13, 2007 | 05:09 AM
richhowerton's Avatar
I just ordered a set of EBC pads I am glad to here they are good.
Old Sep 13, 2007 | 11:45 AM
TCIRACING's Avatar
REMEMBER TO CHECK YOUR ROTOR THICKNESS (THERE'S A MINIMUM THICKNESS NUMBER INDICATED ONTHE SIDE OF YOURROTOR) AND IF THEY'RE SPINNING STRAIGHT, ONCE THAT'S TAKEN CARE OF YOUR PADS SHOULD BE BROKEN IN ABOUT 20 MILES. I USE THE DOUBLE H PADS AND IT'S GIVING ME PRETTY GOOD BRAKING POWER.
Old Sep 14, 2007 | 03:18 PM
gixbusa's Avatar
that lube stuff is like 2 bucks....autozone....or o'reillys has it....
hondachris1994
Mar 6, 2009 12:21 AM
Wildcard
Jun 8, 2008 09:37 PM
D2VW14_20
Jul 17, 2006 01:40 PM
JC1000RR
Mar 21, 2006 06:24 PM
JC1000RR
Feb 13, 2006 08:25 PM
