Lifting the front end
Old Apr 3, 2012 | 06:28 PM
Shueisha's Avatar
Default Lifting the front end
Heya guys,
I feel like a bit of an idiot now, I had to take both my wheels off and drop them down to the garage and get my new tires fitted. So I had the rear on a paddock stand and the front on blocks whilst this was happening. I have to replace the fork seals, but I cannot lift the front high enough to get the forks out, I have no front stand. I was thinking a ratchet stap under the yoke with a frame I can build would that work?
Ta
Tris
Old Apr 3, 2012 | 06:50 PM
gotcbr's Avatar
See this thread for some helpful recommendations... https://cbrforum.com/forum/f4i-main-...-bikes-133565/
I use a front stand that lifts by the lower triple (back is also lifted).
You can also use a standard auto floor jack to lift the front by the headers (place a block of wood btwn jack & header).
Engine hoists work well also.
Old Apr 3, 2012 | 07:29 PM
Shueisha's Avatar
Thanks man, I really wanted to avoid using a jack if I could help it, but without those pitbull stands which I can't afford at the moment. It looks like that's the only way I can do it.
Old Apr 4, 2012 | 11:18 AM
polish man's Avatar
when i put tires on mine i used a ratchet strap and made a temp support beam with 4by4s in my garage. coulda lifted the whole bike
Old Apr 4, 2012 | 04:10 PM
Shueisha's Avatar
That's what I was thinking of doing, now I know it will hold it's time to get the hammer out
Old Apr 4, 2012 | 07:12 PM
polish man's Avatar
still had a pic lol
i used screws so i could take it down normally i would just take it to my work n lift it with an engine lift but it wasnt insured at the time
Old Apr 7, 2012 | 06:39 AM
Shueisha's Avatar
That's a good set up man, i'll mimic that at home
Old Apr 7, 2012 | 09:16 PM
bowtieboy42's Avatar
I screwed a big U hook into one of the rafters in the garage and used a ratchet strap. Works great.
removebeforeflight
Sep 19, 2014 05:31 PM
Wooster11
May 14, 2009 11:49 AM
lptwist
Jul 4, 2008 12:14 PM
waz57
Jun 1, 2006 12:37 AM
transamlt1man
Dec 7, 2005 12:33 AM
