Help with Electrical problems please
Old 09-25-2017, 03:46 PM
seebeer's Avatar
Default Help with Electrical problems please
This is my first bike.. It will not start from the switch. Nothing happens. Nothing.
I can jump start it but it backfires every so often.
Recently it cut out when I turned on the lights...
I assumed battery so got a new one, checked power was ok but still did not start after fitting.
I have removed the switch and tested it and the kill switch with a multimeter and seems ok.
The start relay does not click when pressing the starter button bit I could start it when shorting the terminals.
I have a data tag system. I am assuming that this is not the fault.
I suspect starter relay is at fault but could that cause backfires?
Advice appreciated.
see bee r
Old 09-25-2017, 05:12 PM
Gunk's Avatar
My focus would the alarm, they are a pain the ****, I had similar problems and have now removed mine.
Old 09-26-2017, 04:44 PM
seebeer's Avatar
Any tips on how to do this?
Old 09-27-2017, 01:20 AM
Gunk's Avatar
You could open it up remove the internal battery and then disconnect it from the battery terminals.
m21oliver
10-01-2018 10:52 AM
thetrick13
08-11-2009 10:13 AM
maxxheadroom
08-25-2006 06:51 AM
Quick Reply: Help with Electrical problems please
