HELP!!! I need electrical help ASAP please!!!
Old Aug 24, 2006 | 01:28 PM
maxxheadroom's Avatar
Default HELP!!! I need electrical help ASAP please!!!
So this morning I replaced my regulator rectifier, when I pulled the old one off I noticed there was no connector, just spade connectors. Anyway no big deal I get the new one on without issue except the two bottom wires (there are three on the top, two on the bottom) I accidently touched the two together, got a quick spark then they were dead. So I went ahead and finished installing the regulator when I turned the ignition on I got nothing no lights, no horn nothing at all. I checked all the fuses under the cover all fuses are good (I electricaly checked them with my DVOM) so now I am unable to find a wiring diagram for my bike, I am stuck I am supposed to be riding 200 miles today for an interview please help me!!! My bike is a 93 900RR
Old Aug 24, 2006 | 01:35 PM
stephygee's Avatar
Registered Users
Default RE: HELP!!! I need electrical help ASAP please!!!
900RR Manual
WinZip Extractor to unzip the file.
Good luck, young Jedi...
Old Aug 24, 2006 | 01:50 PM
That is the 96-99 manual, I have a 93.
Old Aug 24, 2006 | 01:57 PM
stephygee's Avatar
Registered Users
Was there a significant change between those years? Most often, even though it's a different year, the older/newer manuals still apply.
Kind of like the 01 F4i manual still being applicable for the '06 F4i's.
Old Aug 24, 2006 | 04:01 PM
mikequinn's Avatar
All the yellow wires go to the 3 terminals on the reg
as you look at the reg mounted in the frame the 2 terminals should be behind the yellow 3 wires
the top wire is GREEN and the bottom is RED/WHITE,
On the left of the bike under the seat should be the relay/solenoid, if you can't find it trace the pos+ lead from the battery,
on the relay is a 30A fuse this is the main fuse ,
you might have blown it
Old Aug 24, 2006 | 04:35 PM
rrasco's Avatar
ORIGINAL: mikequinn
+1, the positive lead goes to the solenoid, and without the main fuse, NOTHING gets power.
Old Aug 25, 2006 | 01:34 AM
Thanks for the help everybody! My bike is running great!!!
Old Aug 25, 2006 | 01:40 AM
rrasco's Avatar
was it the main fuse?
Old Aug 25, 2006 | 06:51 AM
mikequinn's Avatar
no worries fella glad to help
monsterenergy08
F2 Tech
May 14, 2012 02:47 PM
diovol
Jul 4, 2011 10:16 PM
florida f4i
Nov 24, 2009 01:10 PM
laxmsoe
Jul 21, 2008 10:29 AM
