Help with Electrical problems please
This is my first bike.. It will not start from the switch. Nothing happens. Nothing.
I can jump start it but it backfires every so often.
Recently it cut out when I turned on the lights...
I assumed battery so got a new one, checked power was ok but still did not start after fitting.
I have removed the switch and tested it and the kill switch with a multimeter and seems ok.
The start relay does not click when pressing the starter button bit I could start it when shorting the terminals.
I have a data tag system. I am assuming that this is not the fault.
I suspect starter relay is at fault but could that cause backfires?
Advice appreciated.
see bee r
Advice appreciated.
see bee r
thetrick13
08-11-2009 10:13 AM
