bike stalls at low rpm - carbs?
Old Nov 12, 2006 | 03:51 PM
slo_rdr's Avatar
Default bike stalls at low rpm - carbs?
Hi, I'm in the process of getting a '99 600F4. Everything looks good (to my novice eyes), Low miles-5900. The present owner said it has sat for a while in the garage & gas was old. I test road it & the thing idles fine it's just that when you give it a little throttle it dies. Only way to make it go was to get it to about 4000 rpm. Result - seller is having carbs cleaned.
My questions are:
If seller road bike like this, could any other, more expensive problems been caused by ******* the bike to keep it going?
I had to really overclutch to avoid launching out on one wheel - is the F4 clutch a wet or dry clutch?
Could the stalling as soon as you give it a little gas be a bigger problem other than clogged carbs?
Thanks in advance!
Old Nov 13, 2006 | 03:22 AM
ajlong's Avatar
Default RE: bike stalls at low rpm - carbs?
Having the carbs cleaned should resolve any issues. Change the oil and coolent too, that way you know when it was last done and you can work out a service routine from there.
Sorry, forgot, they're wet clutches.
Old Nov 13, 2006 | 03:38 PM
slo_rdr's Avatar
Thanks!
One more test ride after it comes from the shop & hope it's mustard!
Thanks for the info on the clutch - Being relatively new, I use it alot & just wanted to make sure so as not to burn it out.
mdgower
Mar 15, 2012 01:45 PM
CBR.600.F4
Nov 16, 2010 12:54 AM
99LS1
Sep 19, 2009 10:10 AM
paulscbr
Oct 27, 2007 05:57 AM
fiveoh
Dec 11, 2006 12:21 AM
