Engine stalls at half a mile, won't restart - carbs?
Old Mar 12, 2012 | 05:03 PM
mdgower's Avatar
New Member
Default Engine stalls at half a mile, won't restart - carbs?
Hi,
Absolute bike novice in need of some advice; I've finally got a license buy my F2 only seems to want to give me fun in bursts - please help!
I have a '93 CBR600 F-P, which for one reason and another sat completely still without being fired up for 10 months; on passing my DAS I could hardly wait to put this bike on the road and get amongst it. Got the bike serviced and MOT'd in on 21st October last year - two days of riding later the battery was completely discharged and couldn't be rescued by my charger. Looking under the seat it was clearly cooked so I bought a new battery and replaced the regulator/rectifier - this resolved the battery problem.
Since then though, the bike has problems starting, which I initially I put down to the cold weather and my being a muppet with a manual choke. Back when I needed the choke, the problem was that generally it'd fire up and settle to what seemed a comfortable idle, but giving it any throttle at all killed the engine. Then it was very reluctant to restart - it'd turn over until the battery died, but only rarely would it catch; if it did though, it would *usually* run okay after that. I wondered if I was flooding the engine and causing the problem, although I couldn't get a strong smell of petrol so am not sure.
Now that it doesn't need choke to start, or at least very little, I find I can ride away on it, but on about 50% of journeys (and rising, I think) the engine will die within the the first half a mile when the revs get too low. Today I could feel it struggling even though I was trundling along at 30mph (just over half a mile into the journey) and then it just cut out - I bump started it while it rolled a halt, but it died again. Both today, and on those previous no-go journeys, once it's dead I can't get it to restart. Again it'll turn over till the battery dies, but no catching at all. After spending the night on the charger I can rinse and repeat, with seemingly a 50/50 chance I'll get beyond half a mile. Yesterday was odd in that after covering a couple of miles in town, the revs started getting much higher than I'd expect - instead of idling at ~1500, it seemed to go up to ~2200 but would settle there. Resolved it by tweaking the idle speed ****, but this was unusual even though it did let me get where I wanted to go.
Back when it needed choke and now that it doesn't, provided it gets past half a mile it does seem to run fine. Indeed, from my very novice point of view there is nothing to indicate a problem once it seems warmed through and is on the go. Perhaps worth saying that generally after a mile I'm on B roads at about 45-60 pretty consistently for at least 10 minutes. So, I'm wondering might any of the following be true:
1. The spark plugs are responsible and need replacing?
2. The carburettors need stripping and cleaning?
3. Have I put too much redex in, in the hope of cleaning the carbs?
Any advice much appreciated - riding was/is such a pleasure but right now it seems pot-luck whether or not I'll be pushing it back to the house in the morning!
Thanks,
Mark
Old Mar 12, 2012 | 08:04 PM
MadHattr059's Avatar
I'm thinking you should re-visit the r/r. Do you have basic electrical skills?
Can you use a multi-meter, do you have one? If so, here's a clear how-to on
checking the charging system and figuring out if it is all performing properly.
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
On another note, Check the fuel-filter and petcock filters for blockage/clogging.
This is a little more of a reach, but easy and it never hurts to give them a little love.
Ern
Old Mar 14, 2012 | 05:46 PM
mdgower's Avatar
New Member
Thanks Ern - I hope to get the tank and check/clean fuel and petcock filters at the weekend. Forgive my ignorance, but are the not the same thing on the F2?
Why do you think it could still be the R/R? When I had a problem with that before the battery had very clearly cooked and it also wouldn't take and hold a charge; that's not the case now and even when it won't catch it'll at least turn over for a good five minutes (it feels like). I guess it could be non-obviously broken with different symptoms then.
Thanks,
Mark
Old Mar 14, 2012 | 07:14 PM
Most of the symptoms match, and this is the easiest, cheapest way for you to start
figuring it out. Follow the link, check the system and determine if it is/isn't the issue.
Then we can go on from there. If I list an entire flow-chart of possibilities, I would be
spending a hour per post. That would limit my ability, to assist all of the folks I would
like to. Fuel/carb problems generally aren't "on/off", if it's related to those issues the
bike runs like crud, all of the time.
Hope this helps, Ern
Old Mar 14, 2012 | 09:56 PM
Sprock's Avatar
Check your choke operation too, really you should not need to be adjusting the idle screw - I'm thinking the choke is sticking potentially..... my 2 cents
Old Mar 15, 2012 | 01:45 PM
vfrman's Avatar
Party Animal, ROTM June 2014
Yep... I was going to mention the sticking choke as well. That is my bet.
fluxcapacitor
Nov 24, 2014 02:50 PM
Hondaowner
Sep 20, 2010 09:49 AM
99LS1
Sep 19, 2009 10:10 AM
d_dub
May 28, 2008 03:33 AM
slo_rdr
Nov 13, 2006 03:38 PM
