WIRE PROBLEM!
Old Aug 3, 2008 | 08:46 AM
SilverF3's Avatar
Default WIRE PROBLEM!
I had this problem that every time i put the bike into gear it shut off like the sidestand was on. then i cut the two power wires and jumped them then when i pulled my clutch in the sidestand came on. then i cut all the wires and jumped the ground to the G/W power and left the other power open. Worked like a charm. But now It blow out my R/R or somthing because the bike just died when riding and wont stay charged, If i grounded out the other power would this fix my problem, Any help would be great thanks.
Old Aug 5, 2008 | 12:44 PM
SilverF3's Avatar
Default RE: WIRE PROBLEM!
Bump+ Any one Ok so i know its my R/R which one should i replace it with anyone know whats the best bet. an how to wire it up thanks.
Old Aug 6, 2008 | 09:19 AM
SilverF3's Avatar
ok so i just found out i asked a stupid question because the way wire wired it just means the sidestand is always up,but now the other big question is WHATS THE BEST RR i can wire up to my bike that wil work and wont burn up? thanks for the no response ppl it made me look into it deeper.
Old Aug 6, 2008 | 10:43 AM
marc0011's Avatar
I went with the factory because I wanted to plug it in and go. I have read on here wh.ere guys have used the gsxr r/r with success. It just takes some hacking of the wire harness though. If you search for gsxr regulator/rectifier, you should find some threads on it.
dsenk48
Sep 11, 2013 08:19 PM
Andr3w
Jul 21, 2012 08:39 AM
riclyd
Jul 19, 2010 12:45 PM
jeepcj469
May 15, 2009 10:31 PM
F4iMiller
May 6, 2009 04:37 AM
