Will not start!!! getting upset!
Old Jun 23, 2009 | 04:37 PM
  #21
1998f3's Avatar
"Have you tried hooking the pump up directly to the battery? Leave the pump connected to the tank and have the output dump into a something like a measuring glass or graduated cylinder. When you connect the pump to the battery, let it run for 5 seconds. Multiply the amount in the container by 12 and it should be in the area of 23.7 oz per min. If you're below that... then you've got a bad pump."
-- I have tried that. I have one drop of gas that comes out when I turn on the ignition, and 2 drops that come out when I turn off the key. Nothing is pumping through the pump. I bypassed the relay and checked the voltage at the pump, and it is 12v, so I know that the pump is gone.
Bamer02 - i have a fuel pump...an extra one... --- Any way to ship it to me, and I will test it to see if it is indeed the pump? I will pay to have it shipped back and also whatever it costs you to ship. Thanks guys! I'm hoping a buddy from work can get me a pump and relay to try out and see if that cures everything.
Old Jun 23, 2009 | 04:38 PM
  #22
1998f3's Avatar
"Where are you located if you are not far from me i will help you. I have pulled the carbs off my bike twice and twice off of my buddys F3 it is easy. and i can help check your fuel pump as well."
Thanks, but I am from Akron ohio. That's a bit far. Thanks though!!
Old Jun 24, 2009 | 09:30 PM
  #23
1998f3's Avatar
So, I replaced the pump and the relay just a bit ago. I jumped the relay to put 12v directly to the pump to pump up to the carbs. Plugged the relay back in, and she fired up immediately!! The pump makes a small ticking noise now, but it might go away as I ride it. Just think it has to get lubed up. We'll see how long it lasts, hopefully forever now!! Thanks for all the help.
Old Jun 25, 2009 | 08:48 AM
  #24
marc0011's Avatar
Great to hear that you isolated the problem.
Old Jul 1, 2009 | 02:49 PM
  #25
Thomas's Avatar
Default Relay
If the pump only works when you by-pass the relay, you have a bad relay.
mchl_daly
May 28, 2011 09:59 PM
xtremef4i
Mar 20, 2011 11:17 AM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
jlowellb
Feb 21, 2009 06:18 PM
fuze
Jun 25, 2007 11:04 PM
