Need help installing engine
I am about to install my engine back in my bike and need some tips, also I can't figure out which spacer is which, so need some help, also if you know what size the starter bolts are that would be appreciated.
if you get the rear lower engine mount/bar in that doesnt have a spacer so that goes in just with the nut on the end then you have the massive spacer about 2 - 3 inch long that goes on the rear top which is the one where you have to remove that big alan key thing on the side of the bike and has a big bolt and nut that goes through
then you have 2 spacers that are the same size 1 goes on the front lower smaller bolt mounts and 1 goes on the front top mounts these all become very apparant through a process of looking at the gaps you have left once getting the rear ones in and you should have a small spacer that goes on the opposite side to the front lower one also
sorry i cant really explain it well but once you get the rear ones in you should be able to see. thats what i did last week
jimbo69ny
May 24, 2009 03:39 AM
