Need help installing engine
Old Jul 21, 2012 | 03:00 PM
dyracuse's Avatar
Default Need help installing engine
I am about to install my engine back in my bike and need some tips, also I can't figure out which spacer is which, so need some help, also if you know what size the starter bolts are that would be appreciated.
Old Jul 21, 2012 | 04:11 PM
billetproof97's Avatar
A motorcycle manual can help you out. Also there is an online manual somewhere around here. Hope this helps
Old Jul 21, 2012 | 04:19 PM
dyracuse's Avatar
Yeah, but the pics aren't that great in there
Old Jul 21, 2012 | 06:48 PM
Nick Long's Avatar
if you get the rear lower engine mount/bar in that doesnt have a spacer so that goes in just with the nut on the end then you have the massive spacer about 2 - 3 inch long that goes on the rear top which is the one where you have to remove that big alan key thing on the side of the bike and has a big bolt and nut that goes through
then you have 2 spacers that are the same size 1 goes on the front lower smaller bolt mounts and 1 goes on the front top mounts these all become very apparant through a process of looking at the gaps you have left once getting the rear ones in and you should have a small spacer that goes on the opposite side to the front lower one also
sorry i cant really explain it well but once you get the rear ones in you should be able to see. thats what i did last week
Old Jul 27, 2012 | 01:59 AM
dyracuse's Avatar
Thanks, any clues on how to do the hoses and wiring? kinda a rats nest and the manual isn't much help, assumes you magically know where they go
lillon
Mar 2, 2011 10:50 AM
rideoncbr
May 27, 2010 03:49 PM
llamonica21
May 20, 2010 02:03 AM
Ssaba420
Jun 5, 2006 04:38 PM
