need help installing jet kit
Old May 18, 2010 | 10:45 PM
rideoncbr's Avatar
Default need help installing jet kit
I got the factory pro jet kit, but 140 on the outside carbs and 142 on the inside carbs, put the new needles in on the 3rd clip from the top.
Started the bike, and it spits around 5-8.
the paper it came with says fuel screw 2 turns to start, I do not know where the fuel screw is, so this is more than likely my problem, anyone know where the fuel screw is, please don't say in the float bowls, I really am hoping to not take the carbs off again.
so I guess my main question is
Where is the fuel screw
This is with giannelli slip on and k&n filter
and are these normal jet selections, or should I have done 38 outside and 40 inside, and Is my clip setting ok?
Old May 19, 2010 | 04:16 AM
rideoncbr's Avatar
ok I found the fuel screw, i set them to 2 turns out from seated, the instructions say 2 turns out, but they dont say if it is 2 turns from seated, or 2 turns from factory setting
Old May 19, 2010 | 10:45 AM
cbr900racer77's Avatar
Lightly seat them then back them out required turns. If it's sputtering from 5-8K rpm's, it isn't your fuel screws but your needles.
Old May 19, 2010 | 11:46 AM
rideoncbr's Avatar
so should I move the clip up a notch or down?
Old May 19, 2010 | 09:27 PM
Only way to tell for sure is to get bike to where it's sputtering and shut motor off, coast to a stop and pull a plug. Or if it's easier, just go one direction and note the change. Whichever way is easier for you.
Old May 20, 2010 | 01:28 AM
rideoncbr's Avatar
ok now I have the needle set to clip #4 which cleared up the sputter, have the fuel screws dialed in, and the bike pulls like crazy up top now, and it runs good down low, but between 5-8 it has a dead spot where it seems to stop making power, but no longer spits and sputters.
I think I should try the last needle adjustment #5, what do you think?
bike runs awesome besides lacking power from 5-8
at 8 the power comes on way harder than ever before and stays on till redline
if the #5 clip setting does not work I will try smaller jets maybe 138 outer and 140 inner
please any thoughts from people with carb/jetting experience would be helpfull, I know jetting is pretty much trial, but experience is everything with this
Old May 20, 2010 | 07:42 PM
If you went to clip pos. #4 you were fattening up the needle. Going to a smaller main would be defeating the purpose as it seem engine is wanting more fuel. Go back up on clip position and try next larger size main.
Old May 21, 2010 | 02:31 AM
rideoncbr's Avatar
i moved the needle to #5, the bike is running good now, no bad spots
if I go one size bigger on the main now, do you think there is more power to gain up top? or would that mean I would have to start all over and find a good needle setting all over agian
as it is now, down low and mid have a really noticable increase in power, up top feels like it gained a little, but I think there is more power to be gained up top by using the bigger jets, the bike definatly is faster tho, really brought the slip on and k&n filter to life!
Old May 21, 2010 | 10:56 AM
It certainly wouldn't hurt to try different sizes. Plug checks are your best friend. They tell you what's going on and they never lie.
Old May 21, 2010 | 03:53 PM
brveagle's Avatar
Why did you purchase a jet kit for a slip on/filter?
I'm curious as to whether you actually are gaining any "power".
Remember, more fuel doesn't equal more power. In fact it's the opposite. Lean is mean.
I run stock jets on my f4 with a D&D pipe and k&n and have no issues what so ever.
