front wheel alignment??
Old Apr 4, 2008 | 06:38 PM
kiddkatana's Avatar
Default front wheel alignment??
I got a 97' F3 about 2 weeks ago, been going thru it, making sure all is ok. I went and bought a new front tire, took it off myself, had the dealer install, put it back together, Now it looks likethe whole thingis too far to the left, from looking at it from the front. What are the difference in the wheel spacers, or is there any? I can tell that from the brake caliper on the right that it is sitting too far to the left, cause it had been scrubbing with the previous owner.. when lookingat the front of bike.. Any info??
Old Apr 5, 2008 | 05:12 AM
pacemaker's Avatar
Default RE: front wheel alignment??
If you think you need to, check the clearances of the caliper bracket-to-disc clearnace (7mm or 0.028inch) with a feeler gauge, its just a matter of loosening of the retaining bolts to slide left or right to make any adjustments.
[IMG]local://upfiles/9500/57057C3D4D9343C284D74F6C220645B9.jpg[/IMG]
[IMG]local://upfiles/9500/056EEDC5477A4DDAACCA334F03C67690.jpg[/IMG]
Old Apr 5, 2008 | 05:13 AM
pacemaker's Avatar
Like this.............
[IMG]local://upfiles/9500/FD92F42C3DB440A9A069C3B471FF5C96.jpg[/IMG]
Also check that you have the spacers on the the correct sides.
Old Apr 5, 2008 | 08:46 AM
kiddkatana's Avatar
ok, here is what I found out... I have a 900rr front wheel, 16", instead of the 17" wheel. Is this gonna make a diff? And what about the spacers? are they different sizes or are they the same size, for the left and right?
Old Apr 7, 2008 | 10:29 PM
Scrufdog's Avatar
left and rght spacers are different sizes. Try switching them.
nthrx
F2 Tech
Jun 3, 2013 04:20 PM
98F3_colorado
May 16, 2011 09:43 PM
SpecR
Mar 1, 2008 04:54 PM
Roger
Jan 5, 2008 07:23 PM
transambird_2000
Jun 16, 2006 08:50 PM
