rear wheel alignment
Old Jun 15, 2006 | 10:37 PM
transambird_2000's Avatar
Default rear wheel alignment
whats the best way of checking it.
Old Jun 15, 2006 | 11:37 PM
ride_002000's Avatar
Default RE: rear wheel alignment
the marks on the rear swing arm
Old Jun 15, 2006 | 11:46 PM
driber's Avatar
Acually those can be a little off.The hash marks on the arm are spaced out almost 4 millimeters. That can be hard to make an acurrate adjustment with the eye. The best way to make sure the wheel is on straight and not cocked, measure from the back adjustment blocks to the end of the swingarm with a 6 inch ruler (precision ruler) you can get this at a home depo or sears for under $5. That way you can be sure that the measurment will be the same on both sides. I use the millimeter side of the ruler and you will be surprised on how far off some peoples wheel is out of line. Even though it LOOKS even it can be off some 3 millimeters by using the marks on the swingarm.
Old Jun 16, 2006 | 08:50 PM
theredgoose's Avatar
I don't use the hash marks on the adjustment blocks. I do this instead......
http://www.motorcycle.com/mo/mcnuts/chassis.html
Congee
Mar 15, 2013 01:34 PM
dracowing14
Jan 3, 2012 01:26 PM
willklee
Jul 14, 2011 10:11 AM
deadfred
F2 Tech
Jul 15, 2010 01:39 PM
Draco88
Aug 27, 2006 05:13 PM
