Do I have a rear wheel alignment issue?
Old Mar 11, 2013 | 01:14 AM
Congee's Avatar
Default Do I have a rear wheel alignment issue?
I recently got some new rubber and thought I had aligned my rear wheel while installing it back on. The notches on the adjustment blocks are pretty close to being the same on either side. I measured from the center of the swingarm pivot to the center of the rear axle and both sides are dead even. However when I look at the rear sprocket, it seems to be favoring one side, such that there's a small gap between the chain and sprocket on the left side.
Does it look like I have an alignment issue or is it normal for the sprocket to not be centered in the middle of the chain?
Any insight would be appreciated.
Old Mar 15, 2013 | 10:54 AM
mnguyen84's Avatar
if ur bike doesn't blow up... i think its fine. now you got me wondering if its like that on my bike.
Old Mar 15, 2013 | 11:40 AM
CorruptFile's Avatar
June 2013 ROTM
To me, that looks fine. The sprocket is designed to have some movement with the chain. The fact you measured it and its even supports this.
On the other hand, I just gunsight the whole thing on my bike. I don't have any alignment tool.
I've heard good things about these:
Chain Alignment Tool | Motion Pro
Old Mar 15, 2013 | 01:34 PM
Incompatible's Avatar
I like to set the alignment using a sprocket tool. First time I used one, I noticed that the swingarm adjustment marks on mine were slightly off.
dracowing14
Jan 3, 2012 01:26 PM
deadfred
F2 Tech
Jul 15, 2010 01:39 PM
gsxr1000nutcase
Feb 27, 2010 11:34 PM
Draco88
Aug 27, 2006 05:13 PM
transambird_2000
Jun 16, 2006 08:50 PM
