f3 stuttering 4k rpm and choke not working
Old Mar 30, 2019 | 06:01 PM
f3non's Avatar
Default f3 stuttering 4k rpm and choke not working
i'm having issues with my (first and new to me) bike. firstly the choke doesn't raise the rpms until the last maybe 1/4 of an inch and when the bike is cold it will raise idle by 500 rpm, did some looking and it seems i either need to try and lube the cable or get a new cable, just figured id mention the issue in the odd chance they are connected. so i have to start it by giving a little throttle and warm it up by holding the throttle open a bit.
main issue is the bike stutters exactly at 4k rpm for maybe 2 seconds then passes it and runs really good. it will do this as long as its in gear, so any amount of throttle.
also seems to run/idle/accelerate >4000 and <4000 normally (although this is my first bike, ive tried to compare with videos, i could be wrong). during the couple seconds it stutters it doesn't even seem to lose power just kind of holds rpm, then will break out of it.
i have read alot of threads on f3 stuttering but the story never lines up with mine.
note - just bought the bike and the stuttering didn't happen on the test drive, i live in iowa its still colder 40-50 degrees, 91 fuel a week old, and bike was just taken out of storage 2 weeks ago
Old Mar 31, 2019 | 02:09 AM
CaBaRet's Avatar
Hi , yes I would take a look at the choke cable adjustment and and the choke enrichment valve operation , just to make sure their opening all the way with your adjustment, maybe even a carb clean
Old Mar 31, 2019 | 06:48 PM
f3non's Avatar
i just tried using seafoam for the first time because i wont have time to do a carb clean for awhile, the seafoam seemed to have bought me some time, it still gets hung up 1 out of 10 times, but i havent gone through the all of the sea foam yet either.
tampa_git
F2 Tech
Jan 27, 2018 02:05 PM
estate4life
May 30, 2012 06:29 PM
Thomas
Jul 1, 2011 08:58 PM
MrGoats
Jan 29, 2010 11:02 AM
Ron
May 10, 2008 06:01 AM
