F3 600 has no power
Old Aug 5, 2012 | 11:17 PM
wings7077's Avatar
New Member
Default F3 600 has no power
hi guys. I have a f3 600. the bike will idle fine. when on the stand i can put it in gear on hammer on the throttle with no issues. when i try to ride it, the bike will take off with good power but start cutting back at like 20 mph. very confused!!! Any ideas?
Old Aug 7, 2012 | 06:26 PM
89cbrcane's Avatar
check your spark plugs, and make sure your plug wires are going to the correct cylinders. Had a similar problem on my old 89 cbr and ended up having the plug wires to #3 and #4 were switched
Old Aug 8, 2012 | 01:58 PM
VEXD's Avatar
Or your air solenoid valve is stuck and needs removing/bypassing.
I'll try to link to the thread if I can find it, hang on.....
https://cbrforum.com/forum/cbr-600f3...83/#post840830
That's a lot easier than it sounds to actually do, and will cause no harm to your bike at slow speeds and of course, will no longer hinder it at high speeds.
If it's the solenoid that's failed and locked into low speed position, it could be causing all of your problems.
CBR forum taught me that.
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
