Cold start?
Old Jul 28, 2013 | 06:15 AM
Killerdimpler's Avatar
Default Cold start?
My bike has a tough time starting when it hasn't been touched over a couple of house. It usually takes a handful of attempt before it's running. But when the engines already worm I can turn it off/on all day long. So my question is what can I do to make my fist attempt to start my bike the right one, or just easier to start the fist time?
Old Jul 28, 2013 | 06:44 AM
Hard starting when cold can generally be traced to fuel and ignition problems. Simple things like replacing spark plugs, replacing the air filter, and or running a can or two of Sea Foam through it. These don't require too much work to do, especially the Sea Foam. Beyond that you're looking at doing a good job on cleaning the carburetors. The choke/enrichment circuits have tiny fuel passageways and get clogged easily, especially if the bike sits for any long period of time.
Old Jul 28, 2013 | 03:14 PM
I replaced the sparkplug, all of them spark. Air filter is a little dirty but should still be good. In order for me to start the bike I have to turn it on while raving the engine. Fuel enrichment circuit?
Old Jul 28, 2013 | 08:21 PM
Do you get the same result whether you use the choke or not ? If so, then yes that is most likely your problem.
Old Jul 29, 2013 | 02:24 PM
I do...
Old Jul 29, 2013 | 08:08 PM
Would using sea foam help with this kind of situation? Or putting a higher octane?
Old Jul 30, 2013 | 02:03 PM
froasty's Avatar
Sounds like tight valves to me. Compression test will test this, or measuring tolerance.
Old Jul 30, 2013 | 10:14 PM
gpfan1's Avatar
You can check the choke cable slack under the airbox too. It pulls on a bar that sets the enrichment level for the carbs. It is held in place by a screw and a clamp. If there is too much slack, you can move the lever all you want and won't get enough enrichment to start it. The cable stretches over time. You can move the cable housing end to get more movement at the bar. Just make sure you don't pull it too tight or you'll always have it on.
My F2 was always a bear to start in winter on early morning rides.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zsomps6
May 27, 2010 07:54 PM
zophill
Apr 20, 2010 07:10 AM
Stiggs
Jan 19, 2010 12:00 AM
