No cold start
Old May 20, 2010 | 11:26 AM
zsomps6's Avatar
Default No cold start
I have a 94 f2 with some starting issues. I bought a new battery for it last season and it worked fine. The first 2 weeks of this season it worked fine. Now when I go to start it in the morning it wont. I have to jump it to get her going in the morning but after it's warmed up it starts fine. I cleaned out the carbs and replaced the plugs because they needed it anyway and was hoping that would solve the problem and it didn't.
Bottom line, it wont start while it's cold, but is totally fine when it's warm. Any help would be awesome.
Old May 20, 2010 | 03:19 PM
bigboi18184's Avatar
Run a battery tender on it when your not riding it, can get one from wal-mart for about $20. Although this may not be the best tender in the world it DOES work very well. It will charge the battery while you aren't riding and when its fully charged will shut off and come back on if the charge starts to dissipate.
Old May 21, 2010 | 02:38 AM
jpanside@gmail.com's Avatar
yeap. ^
I know you bought a battery but it's just a battery problem bro (okay, MOST likely). Trickle charge that hoe.
If it still won't start with choke on and fully charged (green light on tender), then come back and report.
The reason it starts totally fine when warm is because the battery is juiced from being charged at RPMs higher than idle. That is one reasoning for this situation.
good luck bruh
Old May 27, 2010 | 07:54 PM
stretch_the_apex's Avatar
had the same issue with my 2000f4 owned it from 5000 thru 40000 miles it was a cold hearted bitch never wanted to start when it was cold, when i knew i was gunna take it to work or whatever in the morning when it was colder id put a space heater by the bike to warm the engine and everything up sounds weird but it worked fired right up everytime
supermover25
Mar 15, 2019 08:14 PM
Killerdimpler
Jul 30, 2013 10:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
Stiggs
Jan 19, 2010 12:00 AM
