wEIRD wEIRD pROBLEM
Old 06-01-2009, 11:57 AM
Mr.S7's Avatar
Question wEIRD wEIRD pROBLEM
So i got this bike, an f2.. with some issues to fix..
most of it is done..
but now here the problem
the bike turns on fine, but when i put the FIrst gear it shuts off!.. Like when the stand is put.. you know..
but the stand foot is not put, actually i disconnected those cables to see if that works, but still..
does any one have any idea WHere shoould i start to look in??
Old 06-01-2009, 12:02 PM
Sand.Man's Avatar
Is your clutch lever functioning properly?
Do a test to make sure your kick-stand switch is working
Old 06-01-2009, 12:18 PM
CaliKush's Avatar
dude if u disconnect the cables it still shuts off when u kick it in first gear man.
Old 06-01-2009, 12:36 PM
tundrafiend01's Avatar
QFT...LOL
You can jump the wires in the wiring harness so it doesn't matter what the kickstand position is. I'd recommend doing this for testing only.
Also, check your clutch and ensure it is adjusted properly. If it's adjusted too loose, the bike will probably lurch forward and stall out.
Old 06-02-2009, 08:09 PM
Mr.S7's Avatar
the cluthcs lever is fine i cheked that also..
Its like , automatiaccly when i put first gear bike shuts off... even if i disconnetc the Side stand switch.
theres other switch upper the Neutral swithc but if i disconnect that bike wont even turn on.. of course..
so . .
any clues?? i mean can´t be serious!?
Old 06-03-2009, 01:42 AM
rolson's Avatar
They already told you, this will MAKE the bike turn off when put into gear. You can't just disconnect it, you must bypass it.
Old 06-03-2009, 08:01 AM
Phil314's Avatar
bypass the side stand switch and if the bike starts, then your side stand switch is bad.
Don't just leave it that way either. Get a new one and install it or that first left turn could be ugly.
Old 06-03-2009, 11:58 AM
rolson's Avatar
Truth. I don't know how many times I've killed my bike because of that. But then again, i'd rather kill the bike then go flying because of the side stand.
Old 06-04-2009, 01:34 AM
Leo_padakin's Avatar
listen to these guys.
pacemaker
08-03-2019 09:35 AM
Santos4288
01-03-2012 11:14 PM
3wheelerlouie
04-15-2009 09:14 AM
ReaperKK
12-09-2007 04:02 PM
CBrizzle2001xxxx
10-11-2005 08:42 PM
Quick Reply: wEIRD wEIRD pROBLEM
