wEIRD wEIRD pROBLEM
So i got this bike, an f2.. with some issues to fix..
most of it is done.. but now here the problem the bike turns on fine, but when i put the FIrst gear it shuts off!.. Like when the stand is put.. you know.. but the stand foot is not put, actually i disconnected those cables to see if that works, but still.. does any one have any idea WHere shoould i start to look in?? |
Is your clutch lever functioning properly?
Do a test to make sure your kick-stand switch is working |
dude if u disconnect the cables it still shuts off when u kick it in first gear man.
Originally Posted by ridinthabay408
(Post 791708)
You can jump the wires in the wiring harness so it doesn't matter what the kickstand position is. I'd recommend doing this for testing only. Also, check your clutch and ensure it is adjusted properly. If it's adjusted too loose, the bike will probably lurch forward and stall out. |
the cluthcs lever is fine i cheked that also..
Its like , automatiaccly when i put first gear bike shuts off... even if i disconnetc the Side stand switch. theres other switch upper the Neutral swithc but if i disconnect that bike wont even turn on.. of course.. so . . any clues?? i mean canīt be serious!? |
Originally Posted by Mr.S7
(Post 792349)
(Post 792349)
Don't just leave it that way either. Get a new one and install it or that first left turn could be ugly. |
Originally Posted by Phil314
(Post 792524)
bypass the side stand switch and if the bike starts, then your side stand switch is bad.
listen to these guys.
