Weird problem with FI
Old Oct 11, 2005 | 07:32 PM
CBrizzle2001xxxx's Avatar
Default Weird problem with FI
So i went to work and my Mph is at 0 while im driving, so i think that cant kill me.
so then my FI light turns on while on the freeway, and now the mph is alright. I turned it off
and waited a bit and now its running fine with the mph working and everything, sounds normal.
please help
Old Oct 11, 2005 | 07:57 PM
OutToWin PAHC's Avatar
Default RE: Weird problem with FI
sounds like a freak problem with the logic. I work in advanced electronics and engineering and thet could be many things. Sounds like you should make sure your connections are all tight exsecially under the nose fairing and seat just check for a loose connection sometimes the harness's arent fully snapped in either from the shop or even factory and they can come loose. Its seems if the ECU may have lost the -12DC on one of the pins and when the power came back either from a connection coming loose then reconnecting it reset this is why the FI light may have come on and since the FI was actually running it would cause it to stay on because it thinks there was an error.
See how this works out for you.
Kev
Old Oct 11, 2005 | 08:42 PM
THanks alot man, and thank you for such a quick response. Im gonna check all my connections and hopefully it will be fine.
cliffordsyoung
Dec 17, 2012 04:18 PM
sportracer07
Oct 19, 2010 07:41 PM
esoracco
Jul 29, 2010 11:10 AM
Mr.S7
Jun 4, 2009 01:34 AM
HondaCbr600F3
Oct 24, 2007 04:55 PM
