ecm problem, weird one.!
Old Jul 5, 2010 | 09:02 PM
esoracco's Avatar
Default ecm problem, weird one.!
ok, so i got a 98 rr. currenty using the ecm of the 96 rr, when i plug the ecm of the 98 the bike won't start, i have 2 98 ecm's, and i know their both good, but it won't start we neither of em. but when i pl;ug the 96 one it works fine. what sensor is bad? or what could it be?
Old Jul 12, 2010 | 09:25 PM
esoracco's Avatar
c'mon anyone?
Old Jul 12, 2010 | 09:28 PM
zaqwert6's Avatar
Nov 2011 ROTM
Does it crank and not start or not crank ?
Old Jul 13, 2010 | 03:12 PM
Hondas Rule's Avatar
The 98-99 has a throttle position sensor, I wonder if that has something to do with your problem. I would check to see if it was unplugged for the 96 ECU, Worth a try. It is located on the carbs throttle shaft
Old Jul 13, 2010 | 06:43 PM
esoracco's Avatar
it does crank but doesn't start. everything is plugged in, just one day it didin't start so i plugged the 96 ecu and worked. after that i've been only using the 96 ecm. would it run better with the 99 ecu? or should i just give up and keep running the 96ecu?
Old Jul 14, 2010 | 01:26 PM
I honestly do not know the answer to that question, The bike was designed to run on the 98 unit. There may be some advantages to the 98 but who knows for sure
Good Luck
Old Jul 29, 2010 | 11:10 AM
Ouisri's Avatar
May be the old owner did modify on 98rr already!!
cliffordsyoung
Dec 17, 2012 04:18 PM
sportracer07
Oct 19, 2010 07:41 PM
Mr.S7
Jun 4, 2009 01:34 AM
HondaCbr600F3
Oct 24, 2007 04:55 PM
CBrizzle2001xxxx
Oct 11, 2005 08:42 PM
