Weird RPM problem
Old Nov 29, 2007 | 07:59 PM
ReaperKK's Avatar
Default Weird RPM problem
Hey everyone so the 94 F2 has been running like a champ but a strange problem started happening yesterday, basically when I get the engine warmed up and I pull the clutch in or put it in neutral the engine revs itself up to 4k rpm maybe a bit more, it continues to do that. The engine has been running the same tempeture for a while although now with it's revving as high as it does at stops it get hotter. Plenty of fluid in the radiator and I haven't changed anything. Garage kept no rain, I have no idea what this could possibly be, anyone here have any ideas. Thanks for the advice, going to sit down and take a hard look tomorrow.
Old Nov 29, 2007 | 09:20 PM
FNQuickF2's Avatar
Default RE: Weird RPM problem
Try playing around with your idle ****...see if it does anything.
RB
Old Nov 29, 2007 | 10:15 PM
BDizzle6685's Avatar
stupid question but...uhavnt been leavinthe choke on have u???
Old Nov 29, 2007 | 10:38 PM
ReaperKK's Avatar
Played with the idle ****, does nothing except drop the rpm down and then it pops right back up, and the choke isn't on.
and things just went from bad to worse:
I went outside on the porch and there was a strong smell of gas coming, I look under the motorcycle and there is a small puddle, all the gas in the engine leaked out and there was still gas in the tank, petcock was set to off. I start it in a few seconds after I put the petcock into the on switch and it immediatly on a cold engine revs to 6k and starting reving higher slowly. The weird thing is that the throttle is responsive and snaps back but it won't go below 6k, damn I'm in a for a long weekend I feel and I was supposed to relax all weekend. Any ideas are greatly appreciated.
Old Dec 4, 2007 | 11:46 AM
kjohnson's Avatar
Crack it open. Remove tank & airbox. Take your time,it's not hard.Can't diagnose something like this until someone takes a look.
Old Dec 9, 2007 | 04:02 PM
ReaperKK's Avatar
Well I cracked it open a few days ago and I got the problem fixed, I synced the carbs up as well as cleaned them and it runs amazing. Now if I could only leave work so I can ride it.
cliffordsyoung
Dec 17, 2012 04:18 PM
esoracco
Jul 29, 2010 11:10 AM
Mr.S7
Jun 4, 2009 01:34 AM
HondaCbr600F3
Oct 24, 2007 04:55 PM
CBrizzle2001xxxx
Oct 11, 2005 08:42 PM
