Speedometer wont work
Old Jan 12, 2010 | 07:35 PM
CBRfenatic93's Avatar
Default Speedometer wont work
For some reason it has stopped working. The bike was dropped a few days ago but it was still working after. I havent had time to look but are there any ideas as to why it would stop working? My RPM gauge is still working fine and all lights are also working. My temp gauge broke before i even got the bike but i think its just the wiring to the sesor that is broke for the temp gauge. I just wanna know why the speed one is busted?
Thank you
Old Jan 12, 2010 | 08:13 PM
jnicola's Avatar
Check that the cable hasn't been dinged. If it isn't noticeably dinged, make sure it's connection to the axle assembly is snug.
If all that visually appears kosher, disconnect the cable from the axle assembly. Attach a power drill to the cable and run the drill. If the speedo moves, your axle assembly is toast. If your speedo doesn't move, remove the cable all the way, and spin one side and see if the other side spins. If it does spin, your gauge is toast. If it doesn't spin, your cable is bad.
Old Jan 12, 2010 | 08:15 PM
JimmyHoffa's Avatar
+1 Just tested a speedometer/cable this way. That'll set you straight.
Old Jan 12, 2010 | 08:20 PM
Alright ill give that a try in the morning when i get off work. Thanks abunch.
Old Jan 13, 2010 | 04:12 AM
Are F3s the only one with a speedometer. Im looking in my service manuel and it only shows a tachometer and coolant gauge for the F2. But the california edition F3 shows a tach, speed and coolant gauge. Just curious?
Old Jan 13, 2010 | 08:29 AM
JimmyHoffa's Avatar
Ahhhh... F3's have an electronic speedo, correct? That could be why. It is showing you all the gauges that aren't purely mechanical...
Old Jan 13, 2010 | 12:46 PM
jnicola's Avatar
Yeah F2's have a speedo gauge, it's just not electronic. It's fed off the axle.
Old Jan 14, 2010 | 12:40 PM
I just tested my cable and it worked fine. When i took it off, the metal tooth that spins the cable fell out. So ima guess i need a new axle assembly.
Old Jan 14, 2010 | 12:45 PM
Just found some on ebay. Only 20 bucks. As far as getting it on there im thinking i gotta take the wheel off the fork huh?
Old Jan 14, 2010 | 01:32 PM
jnicola's Avatar
Yeah loosen the axle, remove it.drop the wheel. Speed assembling is on the axle but plugs into the rim and locks into place against the fork. This is all presuming i recall correctly
Swap out the speedo assembly and off you go.
C Jacob W
Jul 29, 2013 11:03 AM
lseanf954
Sep 27, 2011 06:53 AM
1 oblivion i
F2 Tech
Oct 4, 2010 10:05 PM
brandonf2
Oct 1, 2010 05:16 PM
all_4jah@hotmail.com
Apr 30, 2008 09:22 PM
