removing complete front end? can it be done?
I'm getting ready to tear into a couple F2s that I'm rebuild and was wondering if I can remove the whole front end as a complete unit and not have to take the forks and everything else apart. Like leaving the fork legs in the triple clamps. Is it possible?
thanks in advance
thanks in advance
I think if you remove the triples from the frame you can, but I'm not sure on this. personally, if I keep mine, I want to put an RR front end on it with the inverted forks.
yep...just take the top clamp off, under it you will see the two spanner nuts (which have a luck washer between them).
I can tell you F4i forks/triples go on with minimal effort.
